Enables a peer group and with respect to the next-hop of routes advertised to EBGP peers.
| peer-group-name | Specifies a peer group. |
| 12vpn-evpn | Specifies L2VPN EVPN address-family type. |
| next-hop-unchanged | Enables preserving the BGP next-hop when routes are advertised to EBGP peers (default is disabled). |
Default is that next-hop-unchanged is disabled.
This command enables overriding the specification behavior with respect to the next-hop of routes advertised to EBGP peers. Specifically, it maintains the BGP next-hop for routes advertised to EBGP peers.
When enabling the address family l2vpn-evpn in an EBGP configuration, the option next-hop-unchanged must also be enabled.
The following command enables next-hop unchanged for the BGP peer group pg2 :
enable bgp peer-group pg2 l2vpn-evpn next-hop-unchanged
This command was first available in ExtremeXOS 31.4.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
